kevinskw
第5楼2008/05/24
1. direct conductivity (直读导电率)
2. acid conductivity (酸导电率 --- 是水通过了阳离子树脂后的导电率读数)
3. solfned (softened ???) feedwater acid conductivily <10us/cm (软化后供给水的酸导电率)
4.feedwater with solved solidsor(????) steam boiler
5.The influence of organic conditioning agents shall be respected complementally (有机调节剂的影响应注意补充)
6.with copper alloys in the systen (system ???) the ph value shall be maintained in the range9-10. (在含铜合金的系统, pH值应维持在9-10的范围)
7.volatile alkalizing agents only for the spray water.( 碱性挥发剂只用于喷洒水 --- 这应该是指调节过热器温度的喷洒水)
