【资料】—Continuous flow focused microwave assisted extraction
  • 我在故我思
    2008/05/07
微波消解
  • 这是一篇介绍性的文献,原理性较强。
    Abstract:
    Continuous flow focused microwave assisted extraction (CFFMAE) involves removal of solutes from the solid matrix into the solvent, while the mixture is continuously pumped and heated in a microwave cavity. It is a complex process which involves phenomena such as electromagnetics, heat transfer, mass transfer, and momentum transfer. Because of this complexity, most of the studies on microwave assisted extraction are experimental and are based either on comparison with other extraction techniques or on experimental optimization of the process. There is a need for a fundamental study of the microwave extraction process which would couple all phenomena aforementioned. Herein we discuss the basic phenomena involved in continuous flow focused microwave assisted extraction and the governing equations required to build a comprehensive model of the process.
    文章的插图:
    全文下载:
    全文
