NOTE: Since the analyzer has a limited hard disk space, it is a good habit to periodically delete unused trendings. Nevertheless, when saving a real-time chromatogram or a trending from the DIAGNOSTIC MENU, a pop-up will advise you if the analyzer hard-drive is full. If so, delete trendings from the ANALYSE CHROMATOGRAM MENU with the delete button. 注意:分析仪具有一个有限的硬盘空间,定期清理硬盘不用的趋势图,这是一个好习惯。不过,从诊断菜单里存储一个实时谱图或者趋势图的时候,如果硬盘已满,会弹出一个询问框来问你。如果这样的话,用删除键从分析仪谱图菜单里删除趋势图。
我想知道的是:when saving a real-time chromatogram or a trending from the DIAGNOSTIC MENU, saving和from与or 的关系: 可不可以这样认为:存储的是一个实时谱图,和一个从诊断菜单中提取的趋势图。 或者我原文翻的那样。两者都是从诊断菜单中提取的。请各位专家解答一下!谢谢!
