【求助】谁能帮我把这些摘要译成英文?
专业英语
  • 对国标甜蜜素的测定方法进行改进;
    样品处理时以静置取代吸出正己烷层离心;
    标准曲线取5个浓度制作;
    色谱柱用毛细管柱代替填充柱;
    计算时固体样品与液体样品采用不同的公式计算;
    改进的方法与国标方法测定结果无显著差异;
    改进的方法省时、易操作,更科学规范,适于批量样品的检测.
  • 该帖子已被管理者-设置为精华,下面是奖励记录:
  • 闲鹤野云
    第1楼2008/02/17
    楼主自己先尝试翻译一下,然后我们来帮你改进,也是大家学习的过程。
  • glzjssxl
    第2楼2008/02/17
    主要是专业英语水平太差劲了.憋了好久才憋出这么点,烦请各位帮忙修改!
    第一句:To improve the National Standard Method of Sodium Cyclamate.
    第二句:此句实在不会!
    第三句:The standard cure were made by 5 series of concertration.
    第四句:replaces the fill column with the capillary column.
    第五句:Solid sample and liquid sample adopt a different formula calculation while computing.
    第六句:The results of the improved method and the national standard didn't remarkable difference.
    第七句:The improved method saves time, it is easy to operate ,more science and norm, it's suitable for the examination of batch quantity sample.
    ruojun 发表:楼主自己先尝试翻译一下,然后我们来帮你改进,也是大家学习的过程。
  • 闲鹤野云
    第3楼2008/02/17
    [quote]原文由 glzjssxl 发表:第一句:To improve the National Standard TEST Method FOR of Sodium Cyclamate.
  • 该帖子已被版主-何当奇加5积分,加2经验;加分理由:多谢应助
  • 闲鹤野云
    第4楼2008/02/17
    第二句:此句实在不会!
    样品处理时以静置取代吸出正己烷层离心
    Samples were treated by settlement instead of centrifuge of Hexane layer
  • 闲鹤野云
    第5楼2008/02/17
    第三句:标准曲线取5个浓度制作;
    The standard cure curve was were made prepared with by 5 series of concertrations concentrations.
  • 何当奇
    第6楼2008/02/17
    填充柱 packed column
  • 该帖子已被管理者-设置为精华,下面是奖励记录:加2积分,加5声望
  • 闲鹤野云
    第7楼2008/02/17
    第四句:色谱柱用毛细管柱代替填充柱;
    packed column was replaced by capillary column
  • 闲鹤野云
    第9楼2008/02/17
    第五句:计算时固体样品与液体样品采用不同的公式计算;
    Test results were calculated with different methods for solid samples and liquid samples respectively
  • 闲鹤野云
    第10楼2008/02/17
    第六句:改进的方法与国标方法测定结果无显著差异The results of the improved method and the national standard didn't remarkable difference.
    There was no significant difference in test results between the improved method and the national standard method.
  • 闲鹤野云
    第11楼2008/02/17
    第七句:改进的方法省时、易操作,更科学规范,适于批量样品的检测.The improved method saves time, it is easy to operate ,more science and norm, it's suitable for the examination of batch quantity sample.
    ruojun: 留下这个大家看看如何翻译和修改???
