CSTEE Scientific committee on toxixcity, ecotoxicity and the environment 毒性、突变性、环境科学委员会
d.wt Dry weight / dw 干重
DT50 Period required for 50 percent dissipation (define method of estimation) 分解50%所需的时间(细分的评价方法)
DT50lab Period required for 50 percent dissipation, under laboratory conditions (define method of estimation) 实验室条件下,分解50%所需的时间(细分的评价方法)
DT90 Period required for 90 percent dissipation (define method of estimation) 分解90%所需的时间(细分的评价方法)
DT90field Period required for 90 percent dissipation under field conditions (define method of estimation) 田间条件下,分解90%所需的时间长度(细分的评价方法)
DU Downstream User 下游用户
EC European Commission 欧洲委员会
EC# EC number, number allocated by the Commission of the European Communities as a term used to replace the EINECS / ELINCS / NLP number designation EC号码
EC50 Median effective concentration 中间有效浓度
ECB European Chemicals Bureau 欧洲化学品管理局
ECHA European Chemicals Agency 欧洲化学品管理局
ECT European Community Treaty 欧盟条约
EEC European Economic Community 欧洲经济协会
EINECS European INventory of Existing Commercial chemical Substances.
欧洲现有商用化学物质目录
EINECS (IS) European INventory of Existing Commercial chemical Substances Information System EINECS信系息统
EINECS# European INventory of Existing Commercial chemical Substances index number EINECS号
ELINCS European LIst of Notified Chemical Substances, this list is periodically updated as an Official Journal 欧洲已备案化学物质目录
ELINCS#, ELINCS-No European LIst of Notified Chemical Substances index number
ELINCS检索号
ESIS European chemical Substances Information System 欧洲化学物质信息系统
ESR Existing Substances Regulation 现有物质规章
EU European Union 欧盟
EURATS European Risk Assessment Tracking System 欧洲风险评估追踪系统
EUSES European Union System for the Evaluation of Substances 欧盟物质评估体系
Final RAR Final Risk Assessment Report 最终风险评估报告
GHS Globally Harmonised System 全球协调系统
GLP Good Laboratory Practice 良好实验室规范
gw Gram weight 克重量
HPLC High Pressure Liquid Chromatography 高压液相色谱(法)
HPV High production volume
高吨位水平(生产量或进口量超过1000吨/年的物质)
HPV-LPV (IS) HPV-LPV Chemicals Information System
HPV-LPV化学信息系统
HPVC HPVC (High Production Volume Chemical) 高产水平化学品
IARC International Agency for Research on Cancer 国际肿瘤研究机构
IS Information System 信息体系
ISO International Standards Organisation 国际标准组织
IUCLID International Uniform Chemical Information Database
国际统一化学信息数据库
IUPAC International Union for Pure Applied Chemistry 国际纯应用化学联盟
Koc Organic carbon adsorption coefficient 有机碳吸附系数
Kow Octanol-water partition coefficient 辛醇-水分配系数
L(E)C50 Lethal concentration, median 半数致死浓度
LPVC LPVC (Low Production Volume Chemical) 低产水平化学制品
M/Is Manufacturers/Importers 生产商/进口商
MOS Margins of safety 安全界限
NCD New Chemicals Database 新化学物质数据库
NLP No-Longer Polymers 不再作为聚合体的物质
OECD Organization for Economic Co-operation and Development
经济合作与发展组织
OJ Official Journal of the European Union 欧盟官方期刊
ORATS (IS) Online European Risk Assessment Tracking System
在线欧洲风险评估跟踪系统
PBT Persistent, Bio-accumulative and Toxic 持久性、生物蓄积性和毒性
PEC Predicted environmental concentration 预测的环境浓度
PNEC(s) Predicted no effect concentration(s) 预测的无效浓度
PNECwater Predicted no effect concentration in water 水中预测的无效浓度
