chengjingbao
第3楼2008/07/17
原来是这样啊!谢谢!此章节我是两眼一抹黑,您多费心!
youjian000
第5楼2008/07/17
Once you have selected the analyzer IP to connect to, you can simply click Ok or press return to attempt to connect to it. If your connection attempt succeeds then the IP will be added to the Connection Details drop-down menu to avoid having to re-type it each time this menu is used. The IP Address is found in the REMOTE – REPORT SOFTWARE menu in the K4000NG. This IP is assigned with DHCP, so no static IP can be used with the K4000NG.
一旦选择好需要连接的分析仪IP,你只须简单地点击OK或者按返回,阅读器就会尝试去连接分析仪。如果连接成功,IP将被添加到“连接细节”下拉菜单,以避免每次使用该菜单时都要重新输入。在K4000NG的“遥控…软件报告”菜单里可以找到这个IP地址。IP地址通过动态主机配置协议(DHCP)分配,因而仪器没有使用静态IP。
