ciaclin
第2楼2008/07/27
Maybe 190 nm to 400. At the first company I worked @2005, found the one "crazy" chemist even run the Uv scan on that 2478 detector up to 660 nm.
Also called the Waters, they might reply at Monday, I will keep you posted if have something new.
Thanks for your reply, fy32501.Have a nice weekend.
5年前您用低波长检测过吗?当时是什么情况?
Not sure, boz the first chemist left 3 years ago. Looked up her
notebook, could not find any record of gradient elute @ Low wavelength.
还有只是水与乙腈做流动相也可以不跑梯度吧?
Sometime do really need gradient elute: for one product with 27 ingredients, so do need 0.1% H3PO4 /ACN gradient elute.
Our general mobile phase in the lab is: 0.1% H3PO4, 0.1 % Formic Acid, o.o5 M Sodium Phosphate ect.. with ACN or MeoH.
当波长降低后,乙腈会不会对检测有影响?
If I am not wrong, for the HPLC grade Acetonitrile, the cut-off wavelength at 198 nm, so supposed is OK @ 205, 210 nm.
2487的工作波长范围是多少?
xjtutfl
第3楼2008/07/27
UV灯是有寿命的,一般使用时间长了,在低波长段是很不稳定的,特别是在做梯度洗脱的时候.
ciaclin
第6楼2008/07/29
Update:
Just replace a NEW Uv lamp and change the flow cell.
When use the isocratic, get a decent baseline @ 205, 210, 220, 279 nm
However, after changing back to gradient, the baseline @ 205,210, 220 nm is a crap.
Any comments would be highly appreciated.
