$$lc状态READY PDA状态READY 自动进样器正常进样,此时PDA状态为WAIT FOR START TIME 进样完成后,弹出警告对话框“有个装置不正常,详细见OUTWINDOW”,打开OUTWINDOW后,提示“The relay in the configuration may be wrong or the cable may not be connected. PDA cannot start after the $$lc system runs. In ethernet connection, make sure the group name is connected and the master name is ......" 求专业人士帮忙!! 我怀疑是SYSTEM CONFIGURATION 中配置不对,但是不知道哪不对。
shaohongxia发表:$$lc状态READY PDA状态READY 自动进样器正常进样,此时PDA状态为WAIT FOR START TIME 进样完成后,弹出警告对话框“有个装置不正常,详细见OUTWINDOW”,打开OUTWINDOW后,提示“The relay in the configuration may be wrong or the cable may not be connected. PDA cannot start after the $$lc system runs. In ethernet connection, make sure the group name is connected and the master name is ......" 求专业人士帮忙!! 我怀疑是SYSTEM CONFIGURATION 中配置不对,但是不知道哪不对。
