型号为DSC Q10。使用中出现datafile acceptor is not answering的错误提示,但是运行没有什么问题。 另外仪器无法升温到150度以上,超过150度时自动停止,出现flange temperature limit exceeded的错误信息。但是之前 做相同试验的时候一切正常,没有问题。 测试软件为4.9.1版,但是仪器内部软件没有升过,还是原来的购买时的版本。电脑系统为XP SP2
以下为程序LOG文件 1 26-Aug-2008 10:22:38 D:\DSC\9309\08-08-24-9309.001 2 26-Aug-2008 10:22:38 Run 1 completed and saved. 3 26-Aug-2008 10:12:58 Datafile acceptor is not answering. (681) 4 26-Aug-2008 10:12:26 Run 1 started. 5 26-Aug-2008 10:12:23 Air cool turned off. (837) 6 26-Aug-2008 10:09:46 New day. 7 24-Aug-2008 11:30:04 Instrument rebooted. 8 24-Aug-2008 11:29:55 auto_diag_init_at_boot 9 24-Aug-2008 11:07:27 Datafile not accepted by end of run. Sequence halted. (678) 10 24-Aug-2008 11:07:27 Flange overtemperature. Run terminated. (067) 11 24-Aug-2008 11:05:37 Datafile acceptor is not answering. (681) 12 24-Aug-2008 11:05:03 Run 1 started. 13 24-Aug-2008 11:05:00 Air cool turned off. (837) 14 24-Aug-2008 10:52:19 D:\DSC\9306\08-08-23-9306.001 15 24-Aug-2008 10:52:19 Run 1 completed and saved. 16 24-Aug-2008 10:43:24 Run 1 started. 17 24-Aug-2008 10:43:21 Air cool turned off. (837) 18 24-Aug-2008 10:00:49 D:\DSC\9307\08-08-23-9307.001 19 24-Aug-2008 10:00:49 Run 1 completed and saved. 20 24-Aug-2008 09:50:40 Run 1 started. 21 24-Aug-2008 09:50:37 Air cool turned off. (837) 22 24-Aug-2008 09:49:57 New day. 23 23-Aug-2008 15:54:38 Instrument rebooted. 24 23-Aug-2008 15:54:29 auto_diag_init_at_boot 25 23-Aug-2008 15:39:44 D:\DSC\fu-bin\08-08-23-FW-103.003 26 23-Aug-2008 15:39:44 Run 1 completed and saved. 27 23-Aug-2008 15:39:42 Flange overtemperature. Run terminated. (067) 28 23-Aug-2008 15:38:37 Run 1 started. 29 23-Aug-2008 15:38:34 Air cool turned off. (837) 30 23-Aug-2008 15:38:02 File sent to instrument: C:\FONT\SYSTem08.fnt. (910) 31 23-Aug-2008 15:37:59 File sent to instrument: C:\FONT\SYSTem01.fnt. (910) 32 23-Aug-2008 15:37:56 File sent to instrument: C:\FONT\SYSTem00.fnt. (910) 33 23-Aug-2008 15:37:53 File sent to instrument: C:\FONT\ROMAntri.fnt. (910) 34 23-Aug-2008 15:37:50 File sent to instrument: C:\FONT\ROMAnsim.fnt. (910) 35 23-Aug-2008 15:37:47 File sent to instrument: C:\FONT\NEWYrk60.fnt. (910) 36 23-Aug-2008 15:37:42 File sent to instrument: C:\FONT\LINEs.fnt. (910) 37 23-Aug-2008 15:37:38 File sent to instrument: C:\FONT\6X10.fnt. (910) 38 23-Aug-2008 15:37:35 File sent to instrument: C:\TINYLOGO.pcx. (910) 39 23-Aug-2008 15:26:46 Flange temperature limit exceeded. Cannot start run. (683) 40 23-Aug-2008 15:26:09 D:\DSC\fu-bin\08-08-23-FW-103.002 41 23-Aug-2008 15:26:09 Run 1 completed and saved. 42 23-Aug-2008 15:26:06 Flange overtemperature. Run terminated. (067) 43 23-Aug-2008 15:24:11 Run 1 started. 44 23-Aug-2008 15:24:08 Air cool turned off. (837) 45 23-Aug-2008 15:12:35 Flange temperature limit exceeded. Cannot start run. (683) 46 23-Aug-2008 15:10:42 Flange temperature limit exceeded. Cannot start run. (683) 47 23-Aug-2008 15:10:40 Flange temperature limit exceeded. Cannot start run. (683) 48 23-Aug-2008 15:10:24 D:\DSC\fu-bin\08-08-23-FW-103.001 49 23-Aug-2008 15:10:24 Run 1 completed and saved. 50 23-Aug-2008 15:10:19 Flange overtemperature. Run terminated. (067) 51 23-Aug-2008 15:08:59 Run 1 started. 52 23-Aug-2008 15:08:56 Air cool turned off. (837) 53 23-Aug-2008 15:03:51 Instrument rebooted. 54 23-Aug-2008 15:02:27 Flange temperature limit exceeded. Cannot start run. (7-Aug-23-Aug-2008
15:03:42 MW auto_diag_init_at_boot 55 23-Aug-2008 15:01:23 Flange temperature limit exceeded. Cannot start run. (683) 56 23Aug-2008 15:00:33 Flange temperature limit exceeded. Cannot start run. (683) 57 23-Aug-2008 15:00:11 Flange temperature limit exceeded. Cannot start run. (683) 58 23-Aug-2008 14:59:07 Flange temperature limit exceeded. Cannot start run. (683) 59 23-Aug-2008 14:58:29 Flange temperature limit exceeded. Cannot start run. (683) 60 23-Aug-2008 14:58:04 Flange temperature limit exceeded. Cannot start run. (683) 61 23-Aug-2008 14:57:26 Flange temperature limit exceeded. Cannot start run. (683) 62 23-Aug-2008 14:57:13 Flange temperature limit exceeded. Cannot start run. (683) 63 23-Aug-2008 14:57:08 Flange temperature limit exceeded. Cannot start run. (683) 64 23-Aug-2008 14:56:46 Flange temperature limit exceeded. Cannot start run. (683) 65 23-Aug-2008 14:56:36 Flange temperature limit exceeded. Cannot start run. (683) 66 23-Aug-2008 14:56:30 Datafile not accepted by end of run. Sequence halted. (678) 67 23-Aug-2008 14:56:26 Flange overtemperature. Run terminated. (067)
