eugenec1
第4楼2008/10/15
FDA 有言在先: "The Laboratory Information Bulletin is a communication from the Division of Field Science, ... In many cases, however, the report may not represent completed analytical work. The reader must assure, by appropriate validation procedures, that the reported methods or techniques are reliable and accurate for use as a regulatory method."
