当前位置: 仪器社区 >质谱 > ICP-MS > 帖子详情
【分享】ICP-MS实践指南
  • lilongfei14
    2008/12/04
ICP-MS
  • 第26卷第4期
    2007年4月
    分析试验室
    CHne~ Journal of Analysis Laboratory
    V01.26.No.4
    2O0r7—4
    Preparation of self-assembled monolayer modified bisosensor by mercapto•butanedioic amine com bined
    nickel(Ⅱ)for hydrogen peroxide
    GAN Ning叫一
    , CHEN Ni ,GE Cong-xin ,WANG Zhi-yir~ and XU Wei-min (1.The State Key Laboratory base of
    Novel Functional Materials and Preparation science,Ninbo University,Ningbo 315211;2.Life faculty of Nanjing
    Univerisity,Nanjing 210009),Fenxi Shiyanshi,2007,26(4):6~10
    Abstract:Mercapto—butanedioic amine combined nickel(Ⅱ)(NiL—SH)monolayer film was developed for the fabfi.
    cation of an amperometric hydrogen peroxide(H202)biosensor.NiL—SH Was modified on Au electrode surface as all
    electron mediator by self-assemb le technique and showed good electmactivity to H2 02.Effects of some experimental
    conditions such as pH,applied potential on the response current of the biosensor were investigated.Th e biosensor had
    a fast response to H2O2 less than 10 s and linear calibration range from 5.0×10一 to 3.0×10-’mol/L with a correla—
    ti0n coefficient 0f 0.999.Th e detecti0n limit Was 2.0×10一 mol/L for H2O .Th e electrode has simulated enzyme
    property.Th e mi chaelis•menten constant KM Was found to be 2.78 mmol/L.Both sensitivity and selectivity of the
    biosensor were investigated.Th is method Was used to determine H2 O2 in real samples.
    Keywords:Hydrogen peroxide biosensor;Metcapto—butanedionic amine comb ined nickel(Ⅱ);Horsemdish peroxi•
    dase;SeIf-assemb led monolayer;Electrocatalysis
    ICP—MS实践指南
    李金英姚继军等译
    (ICP-MS实践指南》是美国Robert Thomas专著{Practical Guide to ICP-MS}的中译本。本书由李金英、姚继军等译,原子能
    出版社2007年4月出版。
    2001年4月,美国Spectroscopy杂志(www.spectmscopyonline.con)发表了Robert Thomas的ICP-MS的系列文章,(Practical
    Guide to ICP—Ms》一书在此基础上成文。该书保留了这些月刊性文章的基本内容,以一种通俗易懂的形式反映了作者从事
    ICP-MS研究20余年的实践经验。
    (ICP-MS实践指南》全书共分20章:ICP-MS概述,包括ICP-MS的工作原理和组成系统的基本部件;简要概述离子形
    成的原理——利用高温氩等离子体生成正电荷离子;样品引入系统—— 等离子体中样品由液态转变为适合电离的细颗粒
    气溶胶,介绍不同类型的商用雾化器和雾室;等离子体源——等离子体放电形成的基本原理;接口区;离子聚焦系统——
    通过静电作用在轴向或垂直方向将待测元素离子从接口区传输至质量分离的装置;质量分析器——将离子按照其质荷比
    (m/z)进行分离的装置,包括四极杆、双聚焦扇形磁场、飞行时间、碰撞/反应池四种质量分离技术;检测器,包括通道式
    电子倍增器和法拉第杯、离散打拿极电子倍增器;峰值测量方案;定量方法,包括外标法、标准加入法及同位素比值法和
    内标法;概述各种干扰,包括谱线干扰、基体干扰以及消除或抑制各种干扰的方法;沾污问题。影响ICP-MS分析结果的主
    要因素包括采样,样品制备、处理、分解过程,试剂和标准的选择,样品制备装置,实验环境及采用的仪器和方法;ICP—
    MS系统各个部件的日常维护;进样附件的选择,包括激光烧蚀进样系统、流动注射分析系统、电热蒸发进样器、去溶装
    置、直接注射雾化器和色谱分离装置等;ICP—MS在环境、生物医学、地球化学、半导体工业、核工业及其他领域如冶金、
    石油化学、食品分析中的应用;ICP-MS与其他原子谱技术在检出限、分析工作范围、样品处理量、常见干扰、实用性、购
    买和运行成本、相关消耗品等方面的比较;从分析性能、检测能力、精密度、准确度、动态范围、技术支持及相关售后服
    务等一些重要方面考虑如何选择ICP-MS
    欲购买者请与原子能出版社联系。
附件:
  • dulcinea
    第1楼2008/12/04
    还以为是书呢....
  • goodball
    第2楼2008/12/04
    原来是在杂志上发表的,现在已经有了合集,我最近刚刚买了一本,很好。
    对初接触ICP-MS有很好的帮助,只是理论的多一些。
  • yuduoling
    第3楼2008/12/28
    楼主有没有电子版的?
  • ykll20062006
    第4楼2008/12/28
    是英文版的啊??
