【求助】二硫代氨基甲酸酯类农残可以用GC-MS检测吗?
农残检测
  • 二硫代氨基甲酸酯类农残,如代森锰锌,福美双等可以用GC-MS检测吗?查了方法,可以用气相做的,是以二硫化碳计算的,还有滴定法。哪位有做过,给点建议,谢谢!
  • 戈壁明珠
    第1楼2009/01/04
    我用气相的顶空做过,效果还行。气质法没有做过。
  • 水番
    第3楼2009/01/04
    您好,您用气相做用的是什么检测器?响应值高吗?谢谢!
    zongguitang 发表:我用气相的顶空做过,效果还行。气质法没有做过。
  • 雾非雾
    第4楼2009/01/04
    以二硫化碳或是滴定法做的,检测限都比较高,满足不了0.01的要求的.代森锰锌,福美双都要用单独法做前处理吧.
    lnyangmei 发表:二硫代氨基甲酸酯类农残,如代森锰锌,福美双等可以用GC-MS检测吗?查了方法,可以用气相做的,是以二硫化碳计算的,还有滴定法。哪位有做过,给点建议,谢谢!
  • yangmei
    第5楼2009/01/05
    除了用气相,那还能用什么方法来做?滴定法或分光光度计法?
    realtiger 发表:这种农药气相很不好做
  • 我在故我思
    第6楼2009/01/05
    2.2 For Mancozeb in Water
    An 8 mL portion of sample was placed into a 40 mL vial along with 10% EDTA, and 3% nCl2/8N HCl solution and capped. The samples were placed in a heating block at 100℃for four hours with shaking at various time intervals. The samples were then analyzed by GC/MSD
    using SIM.
    附件
  • 我在故我思
    第7楼2009/01/05
    福美双(thiram)可以用液相方法做:
    Determination of tetramethylthiuram disulfide (Thiram) in river water by high-performance liquid chromatography: Micellar versus conventional reversed phase chromatography
    Summary:
    After a comparative study of conventional reversed phase and micellar liquid chromatography a method is described for the determination of the fungicide thiram in river water based on the use of micelles of CTAB. The method involves the extraction/concentration of thiram with a C18 cartridge followed by separation on a C18 reversed-phase column with a mobile phase of 20% (v/v) acetonitrile/0.01 M CTAB in phosphate buffer (pH-6.3), and detection at 254 nm. The method allows the determination of thiram in the presence of other water-soluble dithiocarbamate fungicides (nabam, ziram and ferbam) with a limit of detection of 36 pg mL–1 for a typical 20-fold preconcentration.
    全文:
    附件
  • yangmei
    第8楼2009/01/08
    谢谢各位,谢谢hotdoglet!!
