对于当然的应用,传感器的测量(数据)可以对基础工序或潜在的变化提供过程形迹。(或翻译为:传感器的测量(数据)当然可以对基本工序或潜在的变化提供过程形迹。)基于已知的工艺过程,当这些参数或形迹与产品过程质量有关时(翻译为:当这些参数或形迹关系到产品过程质量时),这些形迹可能也有益于过程检测、控制以及终点的检测。
不知道是满意
wyqsz 发表:For certain applications, sensor-based measurements can provide a useful process signature that may be related to the underlying process steps or transformations. Based on the level of process understanding, these signatures may also be useful for process monitoring, control, and end point determination when these
patterns or signatures relate to product and process quality.
背景:描述PAT(过程分析技术)的工艺过程分析仪。
