luyeaa
第4楼2009/05/31
原话是
Tetraethylammonium Bromide, internal standard
solution—Into a 100-mL volumetric flask weigh approximately
10.80 g of tetraethylammonium bromide (TEAB) to 1
mg.
这篇ASTM标准中还有一句这样的话
Prepare duplicate specimens of the
standard paint, which contains a known concentration of
titanium dioxide, and each test paint using the following
procedure. Into a 20-mL vial weigh approximately 7.00 g of
paint to 1 mg. Pipet 2 mL of TEAB internal standard solution
(see 6.4) into the paint and thoroughly mix.
poorlittle
第7楼2009/05/31
This means that since it is approximately 10.80 g, 10.804, 10.803, 10.802……10.799,…… 10.795 g are all acceptable, but the measurement of the sample weight should be accurate to 0.001 g (i.e. 1 mg).
(Withdrawn, re-consider)
Taking the sample of exactly 10.800 g is not necesarry.
lingzhong
第8楼2009/05/31
一般没有你这种表述方式的
