【讨论】热电DSQ诊断时老出现ROD DC test failed,如何解决?
气质联用(GCMS)
  • 热电DSQ诊断时老出现ROD DC test failed:
    A Rod DC 50 51.7 passed
    B Rod DC 50 50.7 passed
    Average DC 50 51.2 Failed
    Rod DC A/B Switch passed
    热电工程师说不影响做样。个人觉得肯定会影响离子能量,但不知具体有什么影响?
    DSQ在线帮助中这样说:
    Average DC (V)
    Displays the readback value for the average between DC Drivers. This
    value should be within +/- 0.5 V of 50 V. This represents the
    quadrupole offset that determines the average ion energy. If this
    readback fails by a consistent small amount, i.e. 1 V, the instrument
    will still function. You may have to adjust the ion energy to
    compensate.最后一句补偿离子能量,如何操作?
    离子源洗过的,调谐可以通过,目前调谐参数如下:
    Lens 1: -25
    Lens 2: -7.3
    Lens 3: -25
    Prefilter Offset: -5.4
    Electron Lesn: 15
    Electron Energy: -70
    Emission Current: 100
  • cwjzyh
    第1楼2009/09/02
    试着调过调谐液下面一个特别小的螺丝,有点儿变化但就是通不过,请问大家还有什么高招?
  • dickwang2008
    第2楼2009/09/03
    楼主还是问下thermo的工程师,这种硬件问题如果没有遇见过,很难解释!希望楼主问题解决后能将解决方法写出来,大家分享一下。
