何当奇
第1楼2009/09/24
根据分析目的,逐个检测是否和什么样额外范围的条件必须申明。
是 acheck吧? extent additional boundary说的貌似很罗嗦
poorlittle
第3楼2009/09/24
Perhaps the original means “Depending on the objective of the analysis, check (or decise) the necessity and extent of specifying the additional boundary conditions on a case-by-case basis”
My translation:
根据分析之目的对每一个案独立考虑, 是否需要申明additional boundary conditions及其extent.
“boundary conditions” is a technical term. In mathematics, it can be translated as 边界条件. Extent is also a technical term related to boundary conditions, it may be directly translated as 范围, 行内人应明白其含意。
