【分享】井冈霉素A的反相高效液相色谱分析
  • bonna-agela
    2010/05/28
厂商论坛
  • 井冈霉素A的反相高效液相色谱分析
    马婧玮1,陈 黎1
    ,蒋格平2 ,潘灿平1
    (1.中国农业大学 理学院,北京 100094; 2.浙江省义乌市环保局,浙江 义乌 322000)
    摘要:建立了一种用反相高效液相色谱测定井冈霉素A的定量分析方法。使用新型Venusil HILIC液相色谱柱,以乙腈与水不同比例进行梯度洗脱,流速1.0 mL/min,紫外检测波长为210 nm。 该方法的标准偏差为0.24,变异系数为0.42%,回收率在96.5%~101.8%之间,线性相关系数为0.9987。 该方法简便、快速、准确、精密,适用于井冈霉素A 的定量分析。
    关键词:井冈霉素A ;高效液相色谱分析;分析方法
    中图分类号:TQ450.7 文献标志码:A 文章编号:1006-0413(2007)10-0686-02
    Determination of Jingangmycin A by Reversed-phase HPLC
    MA Jing-wei1, CHEN Li1, JIANG Ge-ping2, PAN Can-ping1
    (1.College of Sciences, China Agricultural University, Beijing 100094, China; 2.Agency of Environmental Protection, Yiwu City, Zhejiang Province, Yiwu 322000, Zhejiang, China)
    Abstract:
    A method for quantitative analysis of fungicide jingangmycin A was developed by areversed-phase high performance liquid chromatograph on a Venusil HILIC column by a lineargradient elution of different ratio of acetonitrile/water by volume as mobile phase with 1.0 mL/min flow ratio and UV detection at 210 nm. The standard derivation was 0.24, coefficient of variation was 0.42%, recovery was 96.5 to 101.8%, and the liner correlation coefficient was 0.9987. The method was proved to be simple, quick, accurate and precise to quantitative measure for jingangmycin A.
    Key words: jingangmycin A; high performance liquid chromatography analysis; analysis method
  • 小虾米
    第1楼2012/11/16
    用了你们的柱子吗?
