Utopia
第4楼2010/07/18
帮你直接列出参数,请高手解释:
Name
EXPNO
PROCNO
Acquisition Parameters
Date_
Time
INSTRUM
PROBHD
PULPROG
TD
SOLVENT
NS
DS
SWH
FIDRES
AQ
RG
DW
DE
TE
D1
ZGOPTINS
=======CHANNEL f1=========
NUC1
P1
PL1
SF01
Processing Parameters
SI
SF
WDW
SSB
LB
GB
PC
1D NMR Plot Parameters
CX
CY
F1P
F1
F2P
F2
PPMCM
HZCM
fourhappy
第5楼2010/07/19
EXPNO: experiment number
PROCNO: product number
Date-Time:the date and time of measurement
INSTRUM:spect
PROBHD:probhead type
PULPROG:pulse programme
TD:time domain size
SOLVENT:
NS:numbers of scan
DS:dummy scan
SWH(Hz):Sweep width in Hz
FIDRES:
AQ:acquisition time
RG:receiver gain
DW:dwell time
DE:pre-scan-delay
TE:temperature
D1:relaxation delay, 1-5*T1
TD0: dimension of accumulation loop
----------------f1channel---------------
Nuc1:Nucleus for channel 1 ----1H
P1:F1 channel- 90 degree high power pulse
PL1:F1 channel- power level for pulse (default)
SFO1:Frequency of observe channel
SI:Size of real spectrum
SF:Spectrometer frequency
WDW:window functions for trf, xfb….
SSB:Sine belt shift SSB(0,1,2,…)
LB:Line broadening for em
GB:Gaussian max, position for gm, 0
fourhappy
第6楼2010/07/19
it is for H above.
C谱各参数意义
INSTRUM:spect
TD:time domain size
SOLVENT:
NS:numbers of scan
DS:dummy scan
FIDRES:
AQ:acquisition time
RG:receiver gain
DW:dwell time
DE:pre-scan-delay
TE:temperature
D11:
----------------channel f1---------------
Nuc1:Nucleus for channel 1 ----13C
------------ channel f2---------------
CPDPRG2:
NUC2: Nucleus for channel 1 ----1H
PCPD2:
PL2: F2 channel- power level for pulse
PL12:
PL2W: F2 channel- power level for pulse
SFO2: Frequency of decouple channel
