山石
第3楼2010/10/19
我这有部分英文资料, 供大家参考。
4. Organotin Compounds | |
Description: | Organotins are a class of chemicals combining tin and organics such as butyl and phenyl groups. Organotins are predominantly found in the environment as antifoulants in marine paints, but they can also be used as biocides (antibacterials), and/or heat stabilizers in plastics. |
Where they may be found: | In textiles and apparel, organotins may be associated with plastics, inks, paints, and heat transfer material. Organotins can and have been found in PVC. |
Reason for concern: | Organotins are suspected to be endocrine disrupters. |
