【资料】(比表面及孔隙度分析)氩气测定多种沸石的高精度等温吸附线
  • elliot_cai
    2010/09/28
表界面物性测试
  • 氩气测定多种沸石的高精度等温吸附线
    K. Nakai*, J. Sonoda, M. Yoshida, M. Hakuman and H. Naono
    日本拜耳公司BEL Japan, Inc., 1-9-1 Haradanaka, Toyonaka-shi, Osaka, 561-0807, Japan. E-mail: kazu@nippon-bel.co.jp
    本实验检测了两种不同硅烷醇成分的硅土和两种不同氧化铝(质子)成分的MFI沸石的氩气等温吸附(液氩87.3K)和氮气等温吸附(液氮77.4K)。硅烷醇或质子含量变化对氮气吸附有显著影响,但对氩气吸附的影响非常小。我们在相对压力p/po=10–7–0.99的范围内对七种不同微孔大小的沸石进行了氩气的吸附测定。这七种沸石分别是:MFI (ZSM-5)MTW (ZSM-12)AFI (SSZ-24)AFI (AlPO-5)VFI (VPI-5) [A] 以及LTA (A-Ca) FAU (Y) [B]A组沸石的微孔通道不含笼结构,而B组有笼结构和窗口效应。研究发现:A组沸石氩气原子的Polanyi吸附势只与孔通道尺寸密切相关,而B组沸石氩气原子吸附势与笼尺寸和孔通道大小都相关。
    ……Prior to gas adsorption measurement, the zeolite samples were pretreated in vacuo at 623 K for 10 h. The adsorption isotherms of Ar at 87.3 K (boiling point of liquid argon) and of N2 at 77.4 K (boiling point of liquid nitrogen) were measured by BELSORP-max, which has three pressure transducers of 0.0133 kPa, 1.33 kPa and 133 kPa in full scale. ……
    From Zeolites to Porous MOF Materials – the 40th Anniversary of International Zeol ite Conf erenc e
    选自从沸石到多孔MOF材料”— 40届国际沸石大会
    R. Xu徐如人, Z. Gao,高滋 J. Chen and W. Yan闫文付 (Editors)
    . 2007 Elsevier B.V. All rights reserved.
