【求助】谁有VARIAN ICP-OES(720ES)的维护视频,关于后面空气过滤阀的拆装的?急啊?
  • zhangyingfu138
    2010/11/24
ICP光谱
  • 我想拆下ICP-OES后面的空气过滤阀,苦无视频和资料,所以恳求大虾们施以援手,谢谢!
  • 秋月芙蓉
    第1楼2010/11/30
    视频方面的软件,可以找仪器公司要的
  • zhangyingfu138
    第2楼2010/12/01
    关键是合并后工程师只给电话,没手机,电话工程师没有,报修一个多星期了还没来,郁闷!
  • zhangyingfu138
    第3楼2011/01/14
    通知,已经好了,是空气冷却气的问题!工程师过来维护,现在可以正常使用了!
  • chasel1314
    第4楼2011/01/14
    后面的那个东东就是把上面的黑色塑料螺丝拧开就可以了。
  • zhangyingfu138
    第5楼2011/01/14
    不好意思开始以为空气冷却气的过滤器在后面,不是,在前方!楼上说后面那个应该是冷却水吧!
  • coastaltrading
    第6楼2011/10/18
    PCG549A00005T
    SD-2仪器用泵头单向阀PCG549A00005T
    PrepStar™ SD-2 Solvent Delivery Module
    • Most economical scale-up format for using lower cost, larger particle
    sorbents
    • Reduce costs with the SD-2’s single pump low pressure gradient (LPG)
    capability
    • Process kilograms of sample with up to 1200 mL/min flow rates at back
    pressures up to 1,500 psi
    PrepStar SD-2 Solvent Delivery Module
    Description Part No. Quantity
    (Each)
    PrepStar SD-2 Solvent Delivery Module PCG03SD2PMP 1
    Voltage Converter 230V to 115V
    Necessary for labs with 230V power PCG502500120 1
    PrepStar SD-2 Pump Heads
    Includes one set of pump heads.
    Order with the SD-2 Solvent Delivery Module - factory installed only.
    Maximum Flow
    Rate
    Maximum Pressure
    (psi) Part No. Quantity
    (Set)
    200 mL/min 5000 PCG54G0T0001A 1
    800 mL/min 2500 PCG54S0T0001A 1
    1200 mL/min 1500 PCG54L250001A 1
    PrepStar™ SD-2 Maintenance
    PrepStar SD-2 Maintenance
    Item
    # Description Part No. Quantity
    (Each)
    1 Check Valve Cartridge PCG549A00005T 1
    Spring Seal, White, 5 mm
    for 200 mL System PCG601660210 1
    Spring Seal, White, 10 mm for
    800 mL System PCG601660010 1
    3 Viton O-ring PCG60130088100 1
    4
    Plunger, 5 mm, for 200 mL System PCG6030F3026781 1
    Plunger, 10 mm, for 800 mL System PCG6030F3026771 1
    PrepStar SD-2 Parts Kits
    Parts Kits include one plunger, check valves, seals, fittings, and fuses to perform
    routine maintenanceon one SD-2 solvent delivery module.
    (Kit)
    200 mL/min
    Solvent Delivery Module Parts Kit PCG03SD2KIT2 1
    800 mL/min
    Solvent Delivery Module Parts Kit PCG03SD2KIT8 1
    1200 mL/min
    Solvent Delivery Module Parts Kit PCG03SD2KIT12 1
    Preparative Mast Kits
    • Preparative Mast Kits work with all PrepStar 218, SD-1, and SD-2
    Preparative Solvent Delivery Systems
    • Kits include everything you need but the tubing
    Kits include a Rheodyne preparative injector valve, prime valve, static mixer, and
    sample loop. 50 and 100 mL sample loops are available for the 1200 mL/min Mast Kit.
    Material Flow Rate
    Sample
    Loop
    (mL)
    Part No.
    SS
    50 mL/min 5 393411005
    200 mL/min 10 393411001
    800 mL/min 20 393411002
    1200 mL/min 20 393411003
    Biocompatible 200/800 mL/min 20 PCG0393411004
    Sample Loops
    Note: The 50 and 100 mL sample loops only fit the Prep Mast 1200 mL/min
    injector valve.
    Material Volume
    (mL) Part No.
    SS
    5 PCG06E320005
    10 PCG06E320006
    20 PCG06E320007
    50 PCG06E320008
    100 PCG06E320010
    PEEK
    10 PCG06E3P0006
    20 PCG06E3P0007
