youmei600252 2010/12/15
Bulletin–Standard Up dat ed BS 5852:2006 Bulletin – Standard Up dat ed BS 5852:2006 - Methods of Test for Assessment of the Ignitability of Upholstered Seating by Smouldering and Flaming Ignition Sources Effective from 31 March, 2006, BS 5852:2006 supersedes BS 5852:1990 [1] and become the latest available standard to measure the ignitability of upholstered furniture composites and/or complete pieces of furniture. This is a full revision of the standard which principal changes are to u pd ate references, to bring the standard into line with BS6807 [2] and BS EN 1021 [3], and to incorporate the existing amendments. Flammability is the critical aspect for all types of upholstered furniture. Domestic products must meet the specific regulations in the UK. Upholstered furniture and beds for use in hotels and other contract situations must also meet the regulations with higher requirement. Having over 40 years experience in consumer product testing, Hong Kong Standards and Testing Centre (STC) is the first furniture flammability testing laboratory in Hong Kong accredited under HOKLAS* and also the only SATRA accredited flammability and footwear testing laboratory in Asia. We have full capability in furniture flammability testing according to prevailing international standards and/or your specifications and now is the laboratory providing the widest HOKLAS accredited upholstered furniture flammability test in Hong Kong. Our technical experts are ready to provide you with the quality, professional and worldwide-recognized testing service in fast and controlled turnaround time * Our laboratory is accredited by HKAS for specific tests as listed in the HOKLAS Directory. Note: [1] Since the Furniture and Furnishings ( Fire ) ( Safety) Regulations 1988 refer to the earlier editions of the standard, neither BS5852-1:1979 nor BS 5852-2:1982 can be withdrawn at the present time. [2] BS 6807,Methods of test for assessment of the ignitability of mattress, divans and bed bases with primary and secondary sources of ignition [3] BS EN 1021, Furniture- Assessment of the ignitability of upholstered furniture.
AK-47(冲)
第1楼2010/12/09
木材:木材本身对环境没有任何负面影响,但制材时可能采用灭菌处理,灭菌剂用后能放出有害气体。标准规定,标志产品不许使用经灭菌剂处理过的木制材料。
塑料:塑料在家具中常以构件的形式出现,塑料对环境的影响主要是由它的添加剂决定的。标准禁止使用以下三类化学品为基础的添加剂:镉、铬、铅或汞等重金属或它们的化合物;氯化/卤化烷烃,或溴化二苯醚等有机物;具有甲基、乙基、丙基、丁基、辛基等烷基族的酞。
玻璃:玻璃本身对环境没有危害,但铅装玻璃在标准中是禁止使用的。铅装玻璃是指玻璃嵌入铅制金属框架而成的构件。它的生产与生产废料对环境都有害。铅能积聚于植物、积聚于生物链中。
包装材料:标准规定不许使用含氯的塑料作为包装材料。
haloyu
第2楼2010/12/09
感谢,我需要全文,pdf版或doc都行
youmei600252
第5楼2010/12/15
Note:
