•Determination of Total Bisphenol A in Polycarbonate Consumer Products by LC/MS. Effective 2010-09-29 •Determination of total lead in wax crayons by block digestion DigiPrep (C02.1) •Determination of total lead in surface coating materials in consumer products (C02.2) Effective 2008-11-13 •Determination of Total Lead in Polyvinyl Chloride Products by Closed Vessel Microwave Digestion (C02.3) Effective 2008-01-02 •Determination of Total Lead in Metallic Consumer Products (C02.4) Effective 2008-10-31 •Determination of total lead in wax crayons by closed vessel microwave digestion (C02.5) Effective 2008-10-31 •Determination of fire retardants in textiles by block digestion DigiPREP (C02.6) Effective 2008-11-13 •Determination of Leachable Arsenic (As), Selenium (Se), Cadmium (Cd), Antimony (Sb), and Barium (Ba) in Applied Coatings (C03) Effective 2009-06-15 •Semi-Quantitative Analysis of Consumer Samples for Toxic Metals Using the Agilent 7500a ICP-MS (C04) Effective 2009-06-23 •Determination of total metals in cosmetic samples by closed-vessel microwave digestion and ICP- MS analysis (C05) Effective 2009-11-17 •Determination of Total Mercury in Surface Coating Materials and Applied Coatings (C07) Effective 2006-01-20 •Determination of migratable lead in consumer products (C08) Effective 2008-08-14 •Determination of Leachable Lead in Kettles (C09) Effective 2006-09-06 •Determination of leachable lead and cadmium from glazed ceramics and glassware (C10) Effective 2009-10-07 •Determination of a-pinene and a-terpineol in consumer products (aqueous cleaning agents) by gas chromatography using extraction columns (C11.1) Effective 2007-08-13 •Determination of ethylene glycol and di-ethylene glycol in antifreeze and coolant by gas chromatography (C11.2) Effective 2007-07-26 •Determination of Benzene, Toluene, Ethylbenzene and Xylenes in Consumer Products by Gas Chromatography/Mass Spectrometry (C11.4) Effective 2006-08-08 •Method to identify an unknown analyte by gas chromatography-mass selective detector (C11.5) Effective 2007-08-29 •Determination of the Water Content of Antifreeze, Windshield Washer Fluid and Other Similar Consumer Products (C11.6) Effective 2009-03-27 •Determination of the pH of consumer products in aqueous solutions (C13) Effective 2009-04-24 •Determination of Anions in Consumer Products by Ion Chromatography (C14.1) Effective 2005-10-06 •Determination of acid and alkali reserves in consumer products (C14.2) Effective 2009-04-24 •Analysis of glues and adhesives for cyanoacrylate (C16) Effective 2003-01-16 •Analysis of spectacle frames, toys and children's equipment for cellulose nitrate (C17) Effective 2003-01-20 •Determination of the available chlorine content in bleaches and cleansers (C18) Effective 2003-05-14 •Determination of the flash point of fluids by the closed cup test method (C22) Effective 2009-04-06 •Determination of the flash point of solids, pastes or gels by the closed cup test method (C22.1) Effective 2009-01-13 •Determination of the flame projection and flashpoint of consumer products packaged in aerosol containers (C23) Effective 2008-05-06 •Determination of the flame projection and flashback of consumer products enclosed in pump-spray containers (C23.1) Effective 2008-05-06 •Determination of the flame projection and flashback of cosmetic products (C23.2) Effective 2008-05-06 •Determination of the flame projection and flashback of controlled products (C23.3) Effective 2003-03-06 •Determination of Volatile N-nitrosamines in Infant Feeding Bottle Nipples, Pacifiers, and Other Similar Consumer Products (C24) Effective 2010-09-30 •Determination of Bulk Asbestos by PLM in Consumer Products (C25 ) Effective 2008-11-13 •Detection of asbestos fibres in consumer products (C26) Effective 2003-03-27 •Determination of the kinematic viscosity of transparent and opaque liquids (C27) Effective 2009-09-18 •Beilstein test (C28) Effective 1998-10-29 •Determination of leakage in child resistant containers (C29) Effective 2003-01-29 •Determination of boric acid and salts of boric acid in toys (C30) Effective 2009-06-15 •Sustained combustibility test (C31) Effective 2002-12-02 •Sustained combustibility of aerosol foam of consumer products (C31.2) Effective 2008-03-05 •Determination of the Vapour Pressure of Petroleum Products by Minivap Vp Tester: ASTM D5191 (C32) Effective 2004-07-21 •Determination Of Mixture That Separates In Consumer Chemical Products (C33) Effective 2004-05-31 •Determination of Phthalates in Polyvinyl Chloride Consumer Products (C34) Effective 2007-07-26 •Determination of phthalates in cosmetic products (C34.1) Effective 2008-12-08 •Method to identify unknown polymers and plasticizers by FTIR (C35) Effective 2010-01-05
