求助专业英语翻译
专业英语
  • Determine the concentration of acetate in the test solutionusing the calibration curve generated by the average of the
    readings obtained with the reference solutions. Measure the peak area for acetate. Calculate the percentage content of
    acetateusingthefollowingexpression;
    c = concentration of acetate in the test solution, inmicrograms per millilitre, determined by linearinterpolation of the standard curve for referencesolution (b) ;
    帮忙翻译下啦?谢谢
  • 天晴了
    第1楼2011/08/28
    Determine the concentration of acetate in the test solution using the calibration curve generated by the average of the readings obtained with the reference solutions.
    由对照溶液的平均读数得到校正曲线,用该校正曲线测定供试液中醋酸盐的浓度。
