symmacros
第1楼2011/11/11
Summary Report with Compound Groups
This produces a standard summary report with additional summed groups.
Groups are based on the spelling of compound names, regardless of retention times. For example, if an analysis identifies compounds named xylene-m, xylene-p, and xylene-o, a summed group can be created by specifying xylene as the group name. The group information appears at the bottom of the report (the numbers are invented for this example):
Named Group:xylene's
Summed Responses 15904
Summed Amounts 137 ng/ml
Number of groups:3
Note that if the compounds had been named m-xylene, p-xylene, and o-xylene, grouping would not be possible.
Up to 6 named groups can be defined.
带化合物分组的摘要报告
此操作将生成包含其他汇总组的标准摘要报告。
这些组基于化合物名称的拼写方式,而不考虑保留时间。例如,如果分析可以识别名为 xylene-m、xylene-p 和 xylene-o 的化合物,则可以通过将 xylene 指定为组名称来创建汇总组。组信息将显示在报告底部(专为本例创建了编号):
已命名组: xylene's
汇总的响应: 15904
汇总量: 137 ng/ml
组数: 3
请注意:如果化合物命名为 m-xylene、p-xylene 和 o-xylene,将无法进行分组。
最多可以定义 6 个已命名组。
