kylabs
第2楼2011/12/26
这个条件可以试试看,结构和氯苯胍有些相似,但是极性比氯苯胍更强,应该用这样的柱子和流动相是有保留的。
http://www.microsolvtech.com/hplc/app_chlorhexidine.asp
Column | Cogent Diamond Hydride™, 4µm, 100A | ||||||||
Catalog No. | 70000-7.5P | ||||||||
Dimensions | 4.6 x 75 mm | ||||||||
Solvents |
Gradient |
Injection Vol. | 2 microL | ||||||||
Flow rate | 1.0 mL/min. | ||||||||
Detection | UV 239 nm | ||||||||
Sample | Stock solution: 1 mg/mL chlorhexidine in methanol diluent. Working solution: A 100 µL aliquot of the stock was diluted to 0.1 mg/mL using 900 µL 50% solvent A/ 50% solvent B mixture diluent. | ||||||||
Peak | Chlorhexidine | ||||||||
t0 | 1.0 min |
