cham
第2楼2006/03/26
● D. 在“More...than...”中,肯定“more”后面的而否定“than”后面的,约等于“是……而不是……”如:
7) The difference between pure linguistics and applied linguistics is more apparent than real.
8) This book seems to be more a manual than a text.
9) Catherine is more diligent than intelli-gent.
10) Hearing the loud noise, the boy was more surprised than frightened.
