back-calculated concentration values 怎么翻
专业英语
  • The back-calculated concentration values for each calibration standard expressed as mean relative error were between -1.3% and 1.0% over the calibration range.
  • poorlittle
    第1楼2012/03/02
    以各个校准品的平均相对误差往后推算得出的浓度为校正范围之-1.3%至1.0%
    (因中文没有单双, 可以详细些意译:
    可用每个(each)校准品的平均相对误差往后推算得出其浓度, 这些(values)浓度之值为校正范围之-1.3%至1.0%)
  • rock_rock
    第2楼2012/03/05
    Some problems here:
    It NOT the concentration values between -1.3% to 1.0%. It should be the “mean relative errors of the concentration values” arebetween -1.3% to 1.0%.
    poorlittle(poorlittle) 发表:以各个校准品的平均相对误差往后推算得出的浓度为校正范围之-1.3%至1.0%
    (因中文没有单双, 可以详细些意译:
  • 该帖子已被版主-天晴了加2积分,加2经验;加分理由:积极应助
  • rock_rock
    第3楼2012/03/05
    Besides, the back-calculated concentration here means the concentration read from the calibration curve. The concentration is a bit different from the "true concentration"
  • poorlittle
    第4楼2012/03/05
    I see the problem now. That is why translation of technical article requires technical knowledge. Thanks!
  • 依风1986
    第5楼2012/03/05
    英语那是干干的啊!佩服
