ian.cheng 2012/03/17
organic tin compounds triphenyltin compounds (TPT) 0.001 in articles fragrance musk xylene 81-15-2 0.05 substances musk ketone 81-14-1 0.05 perfluorinated compounds Perfluorooctyl acid (PFOA) and individual salts and esters of PFOA 335-67-1, 3825-26-1, 335-95-5, 2395-00-8, 335-93-3, 335-66-0, 376-27-2, 3108-24-5 0.005 For textiles and other coated materials: 1 μg/m2 DTDMAC 68783-78-8 DODMAC/DSDMAC 107-64-2 surfactants DHTDMAC 61789-80-8 in total 0.1 Bisphenol A 80-05-7 freely available substance: 0.005 from [date],1 0.0025 from [date]2 diethylhexylphtalate (DEHP) 117-81-7 0.1 pentachlorphenol 87-86-5 0.1 other substances triclosan 3380-34-5 0.001 For metals, the prohibition in the first subsection does not apply to natural occurrences in coal, ore and ore concentrate.
ian.cheng
第6楼2012/03/10
"Chap x. Hazardous substances in consumer products
I. Prohibition on certain hazardous substances in consumer products
Section x-1. Purpose
The purpose of this chapter is to limit the harmful effects on human health and the
environment from consumer products, as well as to limit the content of hazardous substances
in waste.
Section x-2. Scope
For consumer products, this chapter shall take precedence to other provisions in these
regulations, unless indicated to the contrary in this chapter.
The chapter does not apply to food products, food packaging, fertilizers, medical
equipment and tobacco, as well as means of transport, permanently mounted equipment for
means of transport and tyres and similar accessories for means of transport.
Section x-3. Definitions
By the term consumer product is meant any product that is intended for consumers or that
can reasonably be expected to be used by consumers, in line with the definition in section 2a
of the Norwegian Act of 11 June 1976 No. 79 relating to the control of products and
consumer services (the Product Control Act). "
ian.cheng
第7楼2012/03/10
"Section x-4. Prohibition on consumer products that contain certain hazardous substances
It is prohibited to produce, import, export or sell consumer products that contain
substances in the table below when the content of the substance in the product's homogeneous
component parts are greater or equal to the limiting values specified in the table.
Group of
substances
Substance encompassed
by the prohibition
CAS No. Limit value
(percent by
weight)
brominated flame
retardants
hexabromocyclododecane
(HBCDD)
25637-99-4, 3194-55-6 0.1
tetrabromobisphenol A
(TBBPA)
79-94-7 1
chlorinated
paraffins
medium-chained
chlorinated paraffins,
C14-C17 (MCCP)
85535-85-9 0.1
arsenic
and arsenic compounds
0.01
lead
and lead compounds
0.01
metals and metallic
compounds
cadmium
and cadmium compounds"
damoguyan
第8楼2012/03/10
谢谢,怎么还没通过啊,有没有官方的链接?
