hunterwang
第1楼2006/04/23
Rodenburg said:
the system is usually designed in such a way that the illumination is parallel at the specimen when the intensity (C2) knob is high.
http://www.rodenburg.org/guide/t1100.html
Peter Goodhew sadi:
when overfocused, beam convergences substantially because electrons come from only cross-over only
http://www.matter.org.uk/tem/lenses/beam_convergence.htm
个人觉得Rodenburg的解释更合理,见他网页中的ray diagram
