阳光的味道
第10楼2012/09/04
Item | Part No-Option | Description | QTY | Unit Price | Amount |
1 | G4350A | Agilent 7820A gc System气相色谱主机 | 1 | 81,955.52 | 81,955.52 |
标配:全程电子流路控制,包括进样口和检测器 | |||||
控压精度:优于0.01 psi | |||||
2 | G4350A-161 | Split/splitless inlet with EPC毛细柱进样口系统带EPC,用于分流/不分流操作,包括数字设定和显示柱头压、柱流量、分流比和所有其他气路参数 | 1 | 16,747.44 | 16,747.44 |
3 | G4350A-210 | FID for Packed & Capillary Column氢火焰离子化检测器(FID)带EPC,用于填充柱和毛细柱 | 1 | 25,183.55 | 25,183.55 |
4 | G4350A-335 | EzChrom Compact Software工作站软件,用于从多达两台7820A gc或者从一台7820A gc和一台1120compact HPLC的组合控制,采集和评价数据 | 1 | 17,244.98 | 17,244.98 |
5 | G4350A-361 | 1 year std. consum. kit for Capillary1年*标准,用于毛细柱的消耗品包 | 1 | 2,554.05 | 2,554.05 |
6 | 19199T | gc Installation Tool Kit for 7820 | 1 | 3,121.09 | 3,121.09 |
7 | C-TBP1TC | Tenex SS TD Tubes, Preconditioned/Capped | 1 | 16,959.09 | 16,959.09 |
8 | C-AT010C | Air Toxics (TO-17) SS Tubes; Pack of 10 | 1 | 19,718.48 | 19,718.48 |
9 | 122-1052 | DB-1 50m, 0.25mm, 0.25u | 1 | 10,023.51 | 10,023.51 |
Remarks: | 小计: | 193,507.71 | |||
运保费: | 9,675.39 | ||||
总计: | 203,183.10 | ||||
