symmacros
第7楼2012/09/19
这个柱子不错
Alkanolamines Application 2033 gc
Separation of diethanolamine and methyl diethanol amine
Technique : gc
Column : 60 m x 0.32 mm Fused silica
CP-Volamine, Part nr. CP7448
gc : Varian 3800 with 1177 injector
Temperature : 35°C, (0.5 min) ‡ 240°C, 30°C/min
Carrier Gas : He, 2 ml/min
Injector : Split 1:20, T = 250°C
Detector : FID, 300°C
Sample Size : 0.1 µl
Concentration range : ca. 5-10% in ethanol
Courtesy : K.Oostdijk, Varian Application laboratory, Middelburg, The Netherlands
