symmacros
第1楼2013/05/25
MacroPad - Is a Rapid Macro Development Environment for the Agilent Technologies Chemstations.
The macro language makes the Agilent Chemstations the most flexible chromatography data systems in the World.
When you need to write macros, MacroPad is a must. It will save you many hours, and even enables you to use features of the Chemstation you may not be aware of.
原来的显示像下面的例子:
现在显示无颜色区分:例如下面的例子:
