测试条件:[GC-2010] Column Oven Temp. :50.0 °C Injection Temp. :300.00 °C Injection Mode :Split Flow Control Mode :Linear Velocity Pressure :53.6 kPa Total Flow :54.0 mL/min Column Flow :1.00 mL/min Linear Velocity :36.3 cm/sec Purge Flow :3.0 mL/min Split Ratio :50.0 High Pressure Injection :OFF Carrier Gas Saver :OFF Splitter Hold :OFF Oven Temp. Program Rate Temperature(°C) Hold Time(min) - 50.0 3.00 15.00 220.0 0.00 20.00 300.0 2.00
[GCMS-QP2010 Plus] IonSourceTemp :250.00 °C Interface Temp. :280.00 °C Solvent Cut Time :0.00 min Detector Gain Mode :Absolute Detector Gain :0.85 kV Threshold :50 [MS Table] --Group 1 - Event 1-- Start Time :0.00min End Time :20.00min ACQ Mode :Scan Event Time :0.50sec Scan Speed :1666 Start m/z :20.00 End m/z :800.00
