jiasheng
第2楼2013/08/29
G.3.23 Hydrochloric acid solution, c(HCl) = (0,07 ± 0,005) mol/l.
Add 5,8 ml 37 % hydrochloric acid (G.3.2) and 250 ml of water(G.3.1) into a 500 ml volumetric flask. Make up to the mark with water (G.3.1) and mix carefully.
我是问0.07摩尔的盐酸是这样配置的?!
依风1986
第3楼2013/08/29
是的,37%的HCL.密度在1.19克/立方厘米,配置完还要标定
