【求助】原子荧光测乳中的总砷
  • 境随心转
    2014/03/21
原子荧光光谱(AFS)
  • 悬赏金额:0积分状态:已解决
  • 用北京吉天的原子荧光测乳中的总砷时,回收率很难达标,请问有什么好的方法没???(回收率范围90%--105%)
  • 该帖子已被版主-尘加2积分,加2经验;加分理由:鼓励
  • huangza
    第1楼2014/03/22
    回收率很好啊,加标过程说说
  • 境随心转
    第2楼2014/03/22
    1000ug/ml---100ug/ml---10ug/ml---0.05ug/ml
  • 境随心转
    第3楼2014/03/22
    huangza(huangza) 发表:回收率很好啊,加标过程说说
  • zhw19811005
    第4楼2014/03/22
    做出的回收率是多少
  • huangza
    第5楼2014/03/22
    看不懂,不好意思
    境随心转(v2862195) 发表:1000ug/ml---100ug/ml---10ug/ml---0.05ug/ml
  • ljx117
    第6楼2014/03/22
    乳品中几乎没有有机砷,直接测量也能保证很好的回收率,不知您如何做的,标准曲线范围多少?加标多少?
    直接测定法
    Non-chromatographic speciation analysis of arsenic and antimony in milk hydride generation atomic fluorescence spectrometry
    Cava-Montesinos, P (Cava-Montesinos, P); de la Guardia, A (de la Guardia, A); Teutsch, C (Teutsch, C); Cervera, ML (Cervera, ML); de la Guardia, M (de la Guardia, M)
    ANALYTICA CHIMICA ACTA
    卷: 493 期: 2 页: 195-203
    出版年: OCT 1 2003
    摘要
    A rapid, high sensitivity method has been developed for the determination of As(III), As(V), Sb(III) and Sb(V) in milk samples by using hydride generation atomic fluorescence spectrometry. The method is based on the leaching of As and Sb from milk through the sonication of samples with aqua regia followed by direct determination of the corresponding hydrides both before and after reduction with KI. It was confirmed by recovery experiments on spiked commercially available samples that neither the reduced nor the oxidized forms of the elements under study or mixtures of the two oxidation states were modified by the room temperature sample treatment with aqua regia. The methodologies developed provided 3sigma limit of detection values of 8.1, 10.3, 5.4 and 7.7 ng l(-1) for As(III), As(V), Sb(III) and Sb(V) in the diluted samples. Average relative standard deviation values of 5.7, 5.5, 8.2 and 4.7% were found for determination of As(III), As(V), Sb(III) and Sb(V) in commercially available samples of different composition and origin containing from 3.5 to 13.6 ng g(-1) total As and from 4.9 to 11.8 ng g(-1) total Sb, it being confirmed that As(V) and Sb(V) are the main species present in the samples analyzed (62 +/- 5 and 73 +/- 5%, respectively). The time required to determine As and Sb species in milk involves 10 min sonication and 30 min prereduction but these steps can be carried out for several sample simultaneously. Additionally the fluorescence measurement step involves less than 20 min for three replicates of all the four measurements required. So, in less than 2 h it is possible to determine the content of As(III), As(V), Sb(III) and Sb(V) in four samples. (C) 2003 Elsevier B.V. All rights reserved
    消解法
    Determination of arsenic and antimony in milk by hydride generation atomic fluorescence spectrometry
    Cava-Montesinos, P (Cava-Montesinos, P); Cervera, ML (Cervera, ML); Pastor, A (Pastor, A); de la Guardia, M (de la Guardia, M)
    TALANTA
    卷: 60 期: 4 页: 787-799
    出版年: JUL 4 2003
    摘要
    A highly sensitive procedure has been developed for total arsenic and antimony determination in milk samples by hydride generation atomic fluorescence spectrometry after microwave-assisted sample digestion. The discrete introduction of 2 ml of digested sample in the automated continuous flow hydride generation system allows us to reduce drastically the sample and HCl consume and to determine several elements from a same sample digestion. The method provides detection limits of 0.006 and 0.003 ng ml(-1), a sensitivity of 2390 and 2840 fluorescence units per ng ml(-1) for As and Sb respectively, and average relative standard deviation of 2.3% for As and 4.8% for Sb. The analysis of cow milk samples, obtained from the Spanish market evidenced the presence of As at concentration levels from 3.4 to 11.6 ng g(-1) and Sb levels from 3.5 to 11.9 ng g(-1), thus in a proportion near to 1:1, which is in contrast with the 10:1 natural ratio between As and Sb and could evidence the effect of the introduction of new alloys and polymer materials in the industrial process of milk:. The method was validated by the comparison of data found for commercial samples by using the proposed procedure and reference methods based on dry-ashing and AFS, and microwave-assisted digestion and inductively coupled plasma mass spectrometry determination. (C) 2003 Elsevier Science B.V. All rights reserved.
    境随心转(v2862195) 发表:用北京吉天的原子荧光测乳中的总砷时,回收率很难达标,请问有什么好的方法没???(回收率范围90%--105%)
  • 小杜先森
    第7楼2014/03/23
    ljx117(ljx117) 发表:乳品中几乎没有有机砷,直接测量也能保证很好的回收率,不知您如何做的,标准曲线范围多少?加标多少?
    直接测定法
    出版年: OCT 1 2003
    摘要
    消解法
    TALANTA
    出版年: JUL 4 2003
    摘要
  • 境随心转
    第8楼2014/03/23
    老师谢谢您的回复,但是我英语不太好,没看懂。我们总砷加标点是0.05mg/kg,范围是90%——105%
  • 境随心转
    第9楼2014/03/23
    大多都是80%多 ,不到90%
    zhw19811005(zhw19811005) 发表:做出的回收率是多少
  • 境随心转
    第10楼2014/03/23
    看不懂,不好意思[/quot
    用10微克每毫升的砷标准储备液配成0.05微克每毫升的总砷的样品,在进行前处理,上机时回收率达不到国标要求的90%——105%。一般都是80%多。
    huangza(huangza) 发表:1000ug/ml---100ug/ml---10ug/ml---0.05ug/ml
