crystal_cai
第5楼2006/09/07
One thing I forgot to mention. For samples may involve further reaction during temperature ramp, you will see worse repeatability. What was the curing temperature for your sample? Is there any post curing existing when you heat sample? If sample cured in room temperature and the conversions of each sample are different, the Tg results will be different definitely because of the reaction heat.
thomas12
第8楼2007/06/21
1、判断Tg时取拐点好像不复合ISO标准、ASTM标准、DIN标准以及国家标准。ISO标准和国家标准都是取两条切线的角平分线与DSC曲线的交点。
2、有松弛峰是比较常见的现象,有松弛峰同样可以得到玻璃化转变温度,如果加热后再测第二次可能有些问题,如果你的样品还有后固化,那么你第二次测得的玻璃化转变温度就会比第一次高,这是固化度又增大的缘故。
所以我觉得有松弛峰没有关系,直接求带松弛的玻璃还转变温度就可以了,没有必要非得把松弛峰除掉
