zwhn2001
第3楼2014/07/14
The growth direction should be related to your image.
From the image you can determine the growth direction, then combine the Diffraction pattern (FFT) to see what is this direction.
Also you should consider whether the magnetic angle(Ci Zhuan Jiao) is corrected by the TEM itself or not. Usually the new TEM( built in recent 10-20 years are corrected by itself.
