第9楼2004/04/01
推荐几个混合标准给你看看
Multi-element Solution 1 10µg/mL: Ce, Dy, Er, Eu, Gd, Ho, La, Lu, Nd, Pr, Sc, Sm, Tb, Th, Tm, Y, Yb (5% HNO3) 100mL CLMS-1
Multi-element Solution 2 10µg/mL: Ag, Al, As, Ba, Be, Bi, Ca, Cd, Co, Cr, Cs, Cu, Fe, Ga, Hg*, In, K, Li, Mg, Mn, Na, Ni, Pb, Rb, Se, Sr, Tl, U, V, Zn (5% HNO3) 100mL CLMS-2
Multi-element Solution 2A 10µg/mL: Ag, Al, As, Ba, Be, Ca, Cd, Co, Cr, Cs, Cu, Fe, Ga, Hg*, K, Li, Mg, Mn, Na, Ni, Pb, Rb, Se, Sr, Tl, U, V, Zn (5% HNO3)Mercury is supplied as a separate solution 100mL CLMS-2A
Multi-element Solution 3 10µg/mL: Au, Hf, Ir, Pd, Pt, Rh, Ru, Sb, Sn, Te(10% HCl/1% HNO3) 100mL CLMS-3
Multi-element Solution 4 10µg/mL: B, Ge, Mo, Nb, P, Re, S, Si, Ta, Ti, W, Zr(H2O/tr HF) 100mL CLMS-4
Multi-element Solution 5 10µg/mL: Be, Bi, Ce, Co, In, Mg, Ni, Pb, U(2% HNO3) 100mL CLMS-5
