florius
第6楼2015/01/21
这是英文原文:
The ISQ mass spectrometer ships with a factory-tested 15 m x 0.25mm i.d. TR-SQC
column, which the Field Service Engineer uses to qualify the instrument. However, once it
gets dirty, you cannot purchase a new one, so you need to install a column that accommodates
the type and quantity of samples you will be running. You should choose a column that gives
you the best possible resolution, analysis speed, and quantitation.
是翻译的问题,看来还是英文原版可靠啊,不过就是看着头疼
symmacros
第7楼2015/01/21
谢谢提供原文,意思很清楚了,不会有误解。
