标准曲线 | |||||||
A道:As | |||||||
标准系列 | 参与拟合 | 标准浓度 | 荧光强度 | 反算浓度 | 误差 | ||
STD.1 | Yes | 0 | 3.668 | 0 | 0 | ||
STD.2 | Yes | 1 | 65.535 | 1.086 | 0.086 | ||
STD.3 | Yes | 2 | 113.373 | 1.932 | -0.068 | ||
STD.4 | Yes | 4 | 234.848 | 4.079 | 0.079 | ||
STD.5 | Yes | 8 | 448.548 | 7.856 | -0.144 | ||
STD.6 | Yes | 16 | 912.453 | 16.056 | 0.056 | ||
曲线参数 | A=56.576 | B=4.096 | C=0.000 | R=0.9999 | |||
拟合方式 | 一次拟合 | 单位 | μg/L | ||||
B道:Hg | |||||||
STD.1 | Yes | 0 | 275.66 | 0.011 | 0.011 | ||
STD.2 | Yes | 0.5 | 595.23 | 0.485 | -0.015 | ||
STD.3 | Yes | 1 | 930.972 | 0.982 | -0.018 | ||
STD.4 | Yes | 2 | 1613.642 | 1.994 | -0.006 | ||
STD.5 | Yes | 4 | 2998.692 | 4.046 | 0.046 | ||
STD.6 | Yes | 8 | 5655.589 | 7.982 | -0.018 | ||
曲线参数 | A=674.988 | B=267.912 | C=0.000 | R=1.0000 | |||
样品测量 | |||||||
序号 | 样品标识 | A:空白 | A:强度 | A:浓度 | B:空白 | B:强度 | B:浓度 |
1 | 样品 | 69.94 | 64.045 | 1.059626 | 338.58 | 6.883 | 0 |
2 | 样品+标 | 69.94 | 232.785 | 4.042178 | 338.58 | 1492.85 | 1.814756 |
3 | 样品+标 | 69.94 | 227.583 | 3.950221 | 338.58 | 1536.41 | 1.87929 |
4 | 样品+标 | 69.94 | 229.46 | 3.983407 | 338.58 | 1546.13 | 1.89369 |
仪器条件 | |||||||
元素名称 | A道:As | B道:Hg | |||||
负高压(200-500V) | 270 | 300 | |||||
总电流(0-150mA) | 60 | 30 | |||||
辅阴极电流(0-100%) | 30 | 0 | |||||
载气流量(300-600ml/min) | 400 | ||||||
屏蔽气流量(800-1100ml/min) | 1000 | ||||||
原子化器高度(mm) | 10 | ||||||
读数时间(1-60s) | 15 | ||||||
延迟时间(0-60s) | 1 |
