sollar
第8楼2016/05/12
After the signal has retumed to zero, move the "CAL-RUN" switch to "RUN" before pressing "RESET". Verify that the LED flashes, indicating that the new calibration value has been accepted.
当信号重新回到0,将“校准-运行”开关打到run档,按下reset开关,然后LED灯会闪烁
另外问一下,自动校准和手动校准有什么区别,我一直用手动校准,工程师教的也是手动校准,没有教自动校准,还有回路校准有什么用?
