表1方法的线性范围、回归方程、检出限和定量限 Tab. 1 Linear ranges, correlation coefficients, limit of detection, limits of quantification of the method |
检测物质 | 线性范围 ρ/(mg/L) | 回归方程 | 相关系数 | 检出限 ω/(mg/kg) | 定量限 ω/(mg/kg) |
碱性橙2 | 1.25-50 | Y=1830.4X-37.56 | 0.9988 | 0.5 | 1.7 |
碱性嫩黄O | 1.25-50 | Y=1744.8X-901.85 | 0.9978 | 0.6 | 2.0 |
碱性橙21 | 1.25-50 | Y=1286.2X-600.96 | 0.9977 | 0.7 | 2.3 |
碱性橙22 | 1.25-50 | Y=2115.1X-956.22 | 0.9979 | 0.5 | 1.7 |
表2方法的日内和日间精密度(n=6) Tab. 2 The intra- and inter-day precision of the method(n=6) |
检测物质 | 日内精密度 | 日间精密度 | |||||
测定范围 ρ/(mg/L) | 测定均值 ρ/(mg/L) | RSD /% | 测定范围 ρ/(mg/L) | 测定均值 ρ/(mg/L) | RSD /% | ||
碱性橙2 | 23.8-25.8 | 24.8 | 3.05 | 21.6-26.7 | 24.7 | 9.58 | |
碱性嫩黄O | 24.2-25.9 | 24.8 | 2.43 | 23.5-27.9 | 25.4 | 6.57 | |
碱性橙21 | 24.8-26.0 | 25.4 | 1.79 | 23.8-26.8 | 25.3 | 4.36 | |
碱性橙22 | 25.1-26.3 | 25.6 | 1.55 | 24.5-25.8 | 25.4 | 2.48 |
表3.方法的加标回收率(n=3) Tab. 3. The spiked recoveries of the method (n=3) |
检测物质 | 本底值 | 加入量 | 测量值 | 回收率 /% | RSD /% | ||
ω/(mg/kg) | |||||||
碱性橙2 | ND | 10.0 | 7.85 | 78.5 | 3.56 | ||
40.0 | 33.7 | 84.3 | 2.53 | ||||
80.0 | 74.5 | 93.1 | 1.96 | ||||
碱性嫩黄O | ND | 10.0 | 7.92 | 79.2 | 4.14 | ||
40.0 | 32.6 | 81.5 | 2.56 | ||||
80.0 | 68.5 | 85.6 | 3.65 | ||||
碱性橙21 | ND | 10.0 | 8.12 | 81.2 | 4.69 | ||
40.0 | 34.1 | 85.3 | 2.47 | ||||
80.0 | 70.3 | 87.9 | 1.32 | ||||
碱性橙22 | ND | 10.0 | 7.36 | 73.6 | 3.28 | ||
40.0 | 31.2 | 78.0 | 1.56 | ||||
80.0 | 69.4 | 86.8 | 1.28 |
