利用有色溶液进行酶标仪期间核查的可行性分析
1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | |
A | A0 | A0 | A0 | A0 | B3 | B3 | B3 | B3 | C3 | C3 | C3 | C3 |
B | A1 | A1 | A1 | A1 | B4 | B4 | B4 | B4 | C4 | C4 | C4 | C4 |
C | A2 | A2 | A2 | A2 | B5 | B5 | B5 | B5 | C5 | C5 | C5 | C5 |
D | A3 | A3 | A3 | A3 | B6 | B6 | B6 | B6 | C6 | C6 | C6 | C6 |
E | A4 | A4 | A4 | A4 | B7 | B7 | B7 | B7 | C7 | C7 | C7 | C7 |
F | A5 | A5 | A5 | A5 | B8 | B8 | B8 | B8 | C8 | C8 | C8 | C8 |
G | A6 | A6 | A6 | A6 | B9 | B9 | B9 | B9 | C9 | C9 | C9 | C9 |
H | A7 | A7 | A7 | A7 | B10 | B10 | B10 | B10 | C10 | C10 | C10 | C10 |
A | 2.824 | 2.903 | 2.927 | 2.706 | 2.908 | 2.899 | 2.975 | 2.958 | 2.793 | 2.807 | 2.803 | 2.839 |
B | 1.706 | 1.713 | 1.713 | 1.665 | 1.843 | 1.850 | 1.805 | 1.837 | 1.617 | 1.614 | 1.614 | 1.609 |
C | 0.849 | 0.865 | 0.867 | 0.844 | 0.949 | 0.945 | 0.928 | 0.951 | 0.821 | 0.816 | 0.816 | 0.820 |
D | 0.438 | 0.445 | 0.440 | 0.431 | 0.480 | 0.475 | 0.487 | 0.490 | 0.426 | 0.419 | 0.420 | 0.421 |
E | 0.230 | 0.231 | 0.231 | 0.227 | 0.256 | 0.262 | 0.261 | 0.260 | 0.221 | 0.221 | 0.217 | 0.221 |
F | 0.131 | 0.131 | 0.131 | 0.132 | 0.144 | 0.144 | 0.145 | 0.145 | 0.124 | 0.125 | 0.121 | 0.121 |
G | 0.086 | 0.084 | 0.082 | 0.079 | 0.087 | 0.090 | 0.088 | 0.088 | 0.077 | 0.076 | 0.075 | 0.075 |
H | 0.057 | 0.061 | 0.057 | 0.056 | 0.059 | 0.059 | 0.059 | 0.059 | 0.050 | 0.051 | 0.051 | 0.051 |
A0 | A1 | A2 | A3 | A4 | A5 | A6 | A7 | |
浓度ppm | 5000 | 2500 | 1250 | 625 | 312 | 156 | 78 | 39 |
OD均值 | 2.840 | 1.699 | 0.856 | 0.439 | 0.230 | 0.131 | 0.083 | 0.058 |
CV% | 3.51 | 1.36 | 1.34 | 1.32 | 0.82 | 0.38 | 3.61 | 3.84 |
B3 | B4 | B5 | B6 | B7 | B8 | B9 | B10 | |
浓度ppm | 125 | 62 | 31 | 16 | 8 | 4 | 2 | 1 |
OD均值 | 2.935 | 1.834 | 0.943 | 0.483 | 0.260 | 0.145 | 0.088 | 0.059 |
CV% | 1.27 | 1.08 | 1.11 | 1.40 | 1.01 | 0.40 | 1.43 | 0.00 |
C3 | C4 | C5 | C6 | C7 | C8 | C9 | C10 | |
OD均值 | 2.811 | 1.614 | 0.818 | 0.422 | 0.220 | 0.123 | 0.076 | 0.051 |
CV% | 0.71 | 0.21 | 0.32 | 0.74 | 0.91 | 1.68 | 1.26 | 0.99 |
回归方程 | 相关系数 | |
重铬酸钾溶液 | y=0.00066769x+0.0262 | 0.9999 |
甲基橙溶液 | y=0.028873x+0.0329 | 1.0000 |
伊文斯蓝溶液 | y=0.025420x+0.0243 | 1.0000 |
栀子花开
第9楼2016/12/30
这个问题分几个层次回答:
1.紫外分光光度计光程只有10mm也没有关系,你只需将结果按2倍系数换算即可。如紫外分光光度计10mm光程测量结果是0.2,那么在酶标仪上5mm光程的测量结果就应该是0.1;
2.为什么酶标仪光程取5mm,因为与紫外分光光度计的10mm光程测量结果换算起来比较容易。
酶标仪的光程也可以是其它数值,这个没关系。
酶标仪的光程如何测量或计算?测量很麻烦,一般直接按酶标板的参数进行计算。我使用的酶标板是COSTAR9018,查官网得到各个参数,根据参数算出溶液高度5mm时体积为142uL,所以取溶液142uL进行测量。如果使用其它酶标板,需要根据其参数调整溶液体积。
3.不同测量波长需要使用不同物质的溶液。450nm使用重铬酸钾溶液,620nm可以使用伊文斯蓝溶液,但其标准曲线应重新测量计算,因为我使用的是630nm,
对于405nm,本人因平时不使用该波长,因此未作研究。据文献报道,可用1mmo;/L对硝基苯酚的10mmol/L氢氧化钠溶液进行测定,你可以试试看。
p3173963
第10楼2017/01/03
好的,谢谢老师,您太厉害了,敬佩!!
