水清鱼读月
第1楼2017/04/24
MAUD软件安装的说明
MAUD软件2.33版本安装,请参照第三页我写的说明。
MAUD2.67以上版本的安装,请参照下方的说明。
2019年1月最新版本MAUD2.84的安装,请参照第三页的说明。MAUD2.84版本只有64位的,没有32位程序。
这里转发一段MAUD作者更新的一段话,用于说明MAUD2.67以上版本的安装。也给出了机器翻译的文稿,我大概顺了一下。请以英文为准。
Windows installation instructions for Maud 2.67 and higher
Posted on June 23, 2016
After downloading the archive, unzip the Maud.zip and put the content (directory Maud) where you want to install it.
The directory should have the following structure:
maud.bat (double click this to start Maud))
lib (directory with libraries)
licenses (directory with various licenses)
plugins (directory to extend Maud capabilities)
jdk (the Java Virtual Machine needed by Maud)
Start Maud by double clicking the maud.bat.
The following problems should not be present from version 2.84 or higher using the new Java 11. In case you find some, please check the notes below and post a comment.
First, if Maud does not start by double clicking maud.bat, most probably you don’t have a valid java version to run Maud. Please download Maud WITH java (the version “complete”). To check if you have the version with Java or without, check if in the directory Maud you have a folder named jre or starting with jre. If not present you downloaded the version without java.
On some Windows installation you may get an error message like:
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
The problem is due to the fact that java has no more the rights to create the Prefs key on the registry. But you can create it manually once and then there are no more problems.
Here are the steps:
Go into your Start Menu and type regedit into the search field. Start regedit.
Navigate to path HKEY_LOCAL_MACHINE\Software\JavaSoft
Right click on the JavaSoft folder and click on New -> Key
Name the new Key Prefs and everything should work.
Questions:
Where is the structure.mdb database? In the new version all these accessory files are located in your Home directory under AppData/Local/maud and another copy is in the Maud examples folder, located at: Documents/maud/examples.
Maud 2.67及更高版本的Windows安装说明
发表于2016年6月23日
下载存档后,解压缩Maud.zip并将内容(目录Maud)放在要安装它的位置。
该目录应具有以下结构:
maud.bat(双击这个开始Maud))
lib(带库的目录)
licenses(具有各种许可证的目录
plugins(扩展Maud功能的目录)
jdk(Maud需要的Java虚拟机)
双击maud.bat启动Maud。
使用新的Java 11版本2.84或更高版本不应出现以下问题。如果您找到了一些,请查看下面的注释并发表评论。
首先,如果Maud没有通过双击maud.bat启动,很可能你没有一个有效的java版本来运行Maud。请下载Maud WITH java(版本“完整”)。要检查您是否拥有Java版本,请检查是否在Maud目录中有一个名为jre的文件夹或以jre开头。如果不存在,则下载的是没有java的版本。
在某些Windows安装上,您可能会收到如下错误消息:
警告:无法在根0x80000002处打开/创建prefs根节点Software \ JavaSoft \ Prefs。 Windows RegCreateKeyEx(...)返回错误代码5。
问题是由于java没有权利在注册表上创建Prefs密钥。但是你可以手动创建一次,然后就没有问题了。
以下是步骤:
进入“开始”菜单,在搜索字段中键入regedit。开始注册。
导航到路径HKEY_LOCAL_MACHINE \ Software \ JavaSoft
右键单击JavaSoft文件夹,然后单击New - > Key
命名新的Key Prefs,一切都应该有效。
问题:
structures.mdb数据库在哪里?在新版本中,所有这些附件文件都位于AppData / Local / maud下的主目录中,另一个副本位于Maud示例文件夹中,位于:Documents / maud / examples。
水清鱼读月
第10楼2017/07/29
仪器信息网这里上传个附件真难受。请到如下地址下载MAUD2.33软件和对应的Java平台,这是我现在在用的版本,适用于win7 32位系统。如果你是64位系统请再留言。
http://caiyun.feixin.10086.cn/sh/uHJFxl9INz7_JT_t
官网上最新的版本是v2.71,从版本号上来看,应该和2.33差别不大,否则就是V3了。用这个版本是考虑和黄老师的教材所用的版本接近,不至于书上界面和实际软件界面差别较大。事实上,MAUD作者做的教程不少是在v1.9版本做的,其中的仪器配置文件和v2.3就不在一个位置,这对于新手是不利的。
PS:
帖子写完了,发现附件居然上传成功了。好吧,我也不删除附件了。上面链接的压缩包中包含了一个MAUD软件安装教程。安装遇到问题的,推荐查看。
