2017/6/3科研仪器英语口语每日一练(发音技巧第一课) This is Daily English Learning of Analytical Instrument. Today we will talk about pronunciation skills. 我们来学习第一个发音技巧,请您记住,发音技巧的使用程度代表着您的口语流利程度,请大家仔细跟读录音:
第一大规律:词尾辅音+词首元音 My name is... I`m afraid... Take a look at it... Not at all. Can I help you? Time is up. Good idea Take it easy. Finish it in minutes if it is not difficult. Try to finish the job as soon as possible. 第二大规律:词尾元音+词首元音 (1)加j Thank you for coming to see me off. I hope you will enjoy it. Hurry up. Don`t worry about it. (2)加w I can do it Go on with your work. How often do you swim? How about seeing a film this evening? 学习总结: 好了,现在您学会了连读,试着在网上下载一篇慢速的VOA,然后按上述您所学到的方法,用铅笔将单词间的连读画出来,再仔细听录音,掌握连读技巧。切记,所有的发音技巧都是为了发音流畅,说话省力而形成的,切不可为了连读而连读。此时您可能在有些明显可以连读但没听到连读的地方,这都是很正常的。
