昨天做了个样品全扫描图,但是用masshunter工作站中NIST谱图库检索的时候发现成分值得怀疑, 和文献(基峰m/z=192)有差异? 文献原文是:The spectra of the 8,13-epoxy-bridged labdanoids (115-120) all display a base peak at m/z 192. Thecorresponding ion is likely to arise, as shown in Scheme R for 12-0x0-manoyloxide (119, Fig. 18), by a cyclic fragmentation process. Subsequent loss of a methyl radical explains the formation of the abundant ionof mass 177. 还请老师能帮忙看看这到底是什么成份, Rt=25.544 处到底是什么成份?是下面115#这种成份吗?
