利用极性和非极性色谱柱共同分析鸡肉香精挥发性成分
图1 极性柱分析鸡肉香精挥发性物质总离子流图
图2 非极性柱分析鸡肉香精挥发性物质总离子流图
No. | RT | Library | Area Pct |
1 | 7.094 | Hexanal | 0.047 |
2 | 7.624 | .ALPHA.-PINENE, (-)- | 0.608 |
3 | 8.552 | Camphene | 2.424 |
4 | 9.708 | Heptanal | 1.169 |
5 | 10.286 | .beta.-Myrcene | 0.179 |
6 | 10.726 | .beta.-Phellandrene | 0.061 |
7 | 11.789 | 1,8-Cineole | 20.111 |
8 | 12.695 | p-Cymene | 0.9 |
9 | 13.162 | 6-Methyl-5-hepten-2-one | 0.063 |
10 | 13.559 | .ALPHA.-TERPINOLENE | 0.044 |
11 | 14.011 | 2-methyltetrahydrofuran-3-thiol | 0.211 |
12 | 14.469 | 2-Furfurylthiol | 0.01 |
13 | 14.627 | Furfural | 0.142 |
14 | 14.93 | Methional | 0.42 |
15 | 15.121 | Rosefuran | 0.079 |
16 | 15.726 | trans-2-trans-4-Heptadienal | 0.053 |
17 | 16.451 | trans-2-trans-4-Heptadienal | 0.863 |
18 | 17.419 | Tetrahydrothiophen-3-one | 0.294 |
19 | 17.924 | Linalool | 0.076 |
20 | 18.242 | Camphor | 8.904 |
21 | 18.712 | Stearic acid | 0.007 |
22 | 19.019 | 2-Acetylpyrazine | 2.547 |
23 | 19.802 | 4-Terpineol | 0.04 |
24 | 20.308 | .alpha.-Cubebene | 0.202 |
25 | 20.419 | Methionol | 0.712 |
26 | 20.849 | Estragole | 0.542 |
27 | 21.483 | Isoborneol | 0.359 |
28 | 21.582 | .BETA. ELEMENE | 0.507 |
29 | 22.295 | trans-Caryophyllene | 0.39 |
30 | 22.681 | Methyl salicylate | 2.195 |
31 | 23.121 | Geranyl acetate | 0.494 |
32 | 23.781 | .gamma.-curcumene | 0.141 |
33 | 24.083 | Anethole | 10.162 |
34 | 24.425 | Zingiberene | 16.396 |
35 | 24.884 | .alpha.-Curcumene | 6.269 |
36 | 25.329 | .beta.-Sesquiphellandrene | 5.708 |
37 | 26.451 | Ethyl maltol | 4.733 |
38 | 27.129 | Furfuryl sulfide | 0.259 |
39 | 27.453 | Cinnamaldehyde | 0.378 |
40 | 29.002 | Farnesol | 0.139 |
41 | 30.078 | Eugenol | 0.233 |
42 | 31.272 | bis(2-methyl-3-furyl)disulfide | 8.622 |
43 | 32.886 | n-Decanoic acid | 0.042 |
44 | 40.831 | Bis(2-furfuryl)disulfide | 0.533 |
No | RT | Library | Area Pct |
1 | 5.026 | Ethyl acetate | 0.328 |
2 | 8.534 | Hexanal | 0.13 |
3 | 9.47 | Furfural | 0.108 |
4 | 10.463 | 2-Methyl-3-furanthiol | 0.108 |
5 | 11.034 | 2-Heptanone | 0.071 |
6 | 11.286 | (Z)-4-Heptenal | 0.07 |
7 | 11.342 | Heptanal | 0.78 |
8 | 11.507 | Methional | 0.238 |
9 | 12.084 | Tricyclene | 0.034 |
10 | 12.409 | .alpha.-PINENE | 0.648 |
11 | 12.872 | Camphene | 2.213 |
12 | 13.535 | .beta.-Phellandrene | 0.102 |
13 | 13.583 | Methionol | 0.099 |
14 | 13.683 | 2-.BETA.-PINENE | 0.105 |
15 | 13.798 | 6-Methyl-5-hepten-2-one | 0.061 |
16 | 13.919 | .beta.-Myrcene | 0.349 |
17 | 14.115 | trans,trans-2,4-Heptadienal | 0.041 |
18 | 14.309 | 2,3,5-trimethyl pyrazine | 0.062 |
19 | 14.408 | l-Phellandrene | 0.161 |
20 | 14.508 | trans,trans-2,4-Heptadienal (E,E)- | 0.429 |
21 | 14.584 | (+)-3-Carene | 0.041 |
22 | 14.747 | .alpha.-Terpinene | 0.118 |
23 | 14.843 | Acetylpyrazine | 2.248 |
24 | 14.972 | 4-Isopropyltoluene | 0.735 |
25 | 15.099 | D-Limonene | 1.65 |
26 | 15.144 | .gamma.-Terpinene | 1.684 |
27 | 15.211 | 1,8-Cineole | 12.169 |
28 | 16.731 | .ALPHA.-TERPINOLENE | 0.065 |
29 | 16.927 | Linalool | 0.089 |
30 | 18.374 | (+)-2-bornanone | 6.37 |
31 | 19.454 | alpha-Terpineol | 0.093 |
32 | 19.61 | Ethyl maltol | 6.393 |
33 | 21.439 | Cinnamaldehyde | 0.328 |
34 | 21.753 | ANETHOLE | 8.307 |
35 | 22.356 | trans,trans-2,4-Decadien-1-al | 1.523 |
36 | 24.252 | BETA-CARYOPHYLLENE | 0.4 |
37 | 25.143 | Camphene | 0.316 |
38 | 25.746 | ALPHA-CARYOPHYLLENE | 0.081 |
39 | 25.913 | BETA-CARYOPHYLLENE | 0.119 |
40 | 26.111 | .alpha.-Curcumene | 5.938 |
41 | 26.369 | Zingiberene | 15.448 |
42 | 26.493 | .alpha.-Farnesene | 2.92 |
43 | 26.641 | .beta. Bisabolene | 4.071 |
44 | 26.996 | .beta.-Sesquiphellandrene | 6.136 |
45 | 27.295 | Bis(2-methyl-3-furyl)disulfide | 12.351 |
46 | 27.586 | .alpha.-Farnesene | 0.363 |
47 | 27.652 | Nerolidol | 0.314 |
48 | 28.757 | zingiberenol | 0.346 |
49 | 30.143 | Bis(2-furfuryl)disulfide | 3.246 |
