rank
第2楼2006/12/30
理解相位循环和梯度场都是建立在product operator基础上的。如果不理解PO,很难解释什么是相位循环。
相位循环的两条定律:
1)If the phase of a pulse or a group of pulses is shifted by phi, then a coherence undergoing a change in coherence order delta(p) experiences a phase shift -phi*delta(p).
例如一个90度脉冲,相位循环为{x,-x}
之前的PO为Iz, 之后为正负Iy, 因为Iy为I+和I-的线性组合,所以
delta(p)为0-(+-1),也就是说coherence的变化为正负1。 那么receive的相位应该是正负1*0,正负1*180,即{x,-x}
2)If a phse cycle uses steps of 360/N then, along with the desired pathway delta(p), pathways delta(p)+-nN, where n=1,2,3,...,will also be selected. all other pathways are suppressed.
例如还是上面的90度脉冲,相位循环步骤为2,N=2,那么想要delta(p)为正负1的话,以下的delta(p)将会被保留:
...-5,-3,-1,1,3,5...
其他的比如-2,0,2等将会被抑制。
