· Output Voltage Range Adjustable From -1.2 V to -37 V · Output Current Capability of 1.5 A Max · Input Regulation Typically 0.01% Per Input- Voltage Change · Output Regulation Typically 0.3% · Peak Output Current Constant Over Temperature Range of Regulator · Ripple Rejection Typically 77 dB · Direct Replacement for Industry-Standard LM237 and LM337 我的天呀,Datasheet 英文的,谁来帮帮我哦!
